主营:工业冷水机,冷水机组,制冷设备,冷却设备,电镀专项使用冷水机,注塑机专项使用冷水机
江苏 南京
水冷式冷水机
压缩机高低压保护,内过热保护
低水位启动紧急信号装置,低水温防冰警报
采用欧美日进口压缩机
制冷系统焊接口采用无氧焊接法,减少氧化物,表面光滑
节流部件采用丹麦丹佛斯、美国艾柯
水箱采用SUS304不锈钢,避免腐蚀漏水
采用不锈钢板式,盘管式,殻管式,翅片式效率高换热器
RS485通讯功能,实现自动化管理
电器采用OMRON.FUJI.TE.LGMOELLER.SCHNEIDER
控制方式:采用进口微电脑或PLC控制
安全保护完善,故障显示,维修、保养无需有经验人员
效率高率之蒸发器及冷凝器,可节省能源30%以上采用两组压缩机头,可单独或共同使用
High/Low pressure protection for compressor and overheating protection inside the machine
Low water level alarm device and low temperature deicing alarm
Imported compressor from Europe,US and Japan
Refrigeration system welding mouth using anaerobic welding method, reduce oxide, smooth surface
Throttle components are Danish danfoss, the United States cycle
Tank use SUS304 stainless steel, not corrosion leakage
Stainless steel plate, coil type, shell and tube type, finned high efficiency heat exchanger
RS485 communication function, realize automation management
Electrical appliances using OMRON. FUJI. TE. LGMOELLER. SCHNEIDER
Control mode: imported microcomputer and PLC control
Safety protection perfect, fault display, maintenance, maintenance without professional
High efficiency of the evaporator and condenser, can adjust energy more than 30%
2 compressor heads, for individual or joint operation
周阳 (联系时请告诉我是"铝道网看到的 信息,会有优惠哦!谢谢!)
bszlzhy@163.com
