主营:数控双头锯,数显双头锯,数字组角机,数控加工中心,多头液压冲床,端面铣,仿形铣,门窗模具
产品简介
高准确三轴数控钻铣床,采进口数控定位系统,一次装夹可实现180度旋转(0度. 90度.-90度三平面)钻铣加工,特别适合各种铝门窗锁孔加工及各种异形铝型材的多面准确钻铣加工。
主要技术参数
1、行程 X axis..................1000mm/2600mm/3000mm
Y axis..........0?=400mm/90?=200mm/-90?=200mm
Z axis..........0?=200mm/90?=150mm/-90?=250mm
2、速度 Y axis...............................30m/min
Z axis...............................25m/min
X axis...............................30m/min
3、定位精度.Z axis..............................?0.02
X axis...............................?0.05
Y axis...............................?0.02
4、伺服电机..X axis..............................1.5KW
Y axis..............................0.4KW
Z axis...............................0.4KW
5、电主轴...Spindle power...........................3KW
Spindle speed.......................18000/min
Spindle taper...........................?16mm
6、机器总功率Total power..............................6KW
7、机器电源............................3phases 380V/50HZ
8、机器尺寸.2.4mx1.5mx1.8m/4mx1.5mx 1.8m/4.5mx1.5mx 1.8m
9、机器重量.......860kg.........1200kg............1500kg
