四川万康节能环保科技有限公司
主营:成都初效空气过滤器,成都制药厂中效空气过滤器,成都高效空气过滤器,成都高效无隔板过滤器,成都高效有隔板过滤器,成都方舱医院空气过滤器,成都W型亚高效过滤器,成都H13H14高效空气过滤器
H13H14超细玻纤空气过滤器生产厂家
●可重复使用多次
●阻力小、风量大
●广泛运用于空调系统的中级过滤
●Adopts reusable times
●Responding to small resistance, air
●Widely used in air conditioning system of intermediate filtration
构成材料及运行条件
Materials and operating conditions
●框材:铝合金或镀锌板外框
●External frane:Aluminum alloy steel or frame
●滤料材质:新型复合无纺布
●Filter material: new composite nonwoven fabric
●滤料颜色:F5(白色)45%(浅黄)、F6(绿色)65%(桔红色)、
F7(粉红色)85%(紫色)、F8(浅黄)95%(深黄)
●Liao color: The F5 (white) 45% (yellow), F6 (green) 65% (orange),
F7 (pink) 85% (purple), F8 (yellow) 95% (deep yellow)
●密封条:醋酸乙酯
●Gasket:EVA
●使用温度、湿度:80℃、80%以内
●Use the highest temperature, humidity:80℃、80%
型号尺寸及其他参数
Standard specification
型号model 外形尺寸Outside Dimensions(mm) 额定风量Rated air flow(m3/h) 初阻力Initial resistance(Pa) 效率(级别)Efficiency(class) 滤料颜色Liao color 袋数pockets
M1-C1 495×295×500mm20″×12″×20″ 1000m3/h
50Pa F5
55Pa F6
60Pa F7
65Pa F8
 40-50% F5
60-70% F6
75-85% F7
85-95% F8(比色法)colorimetric 白色F5White绿色F6Green粉红F7pink浅黄F8yellow 5
M1-C2 495×495×500mm20″×20″×20″ 1800m3/h 5
M1-C3 595×295×500mm24″×12″×20″ 1300m3/h 6
M1-C4 595×495×500mm24″×20″×20″ 2200m3/h 6
M1-C5 595×595×500mm24″×24″×20″ 2600m3/h 8
M1-C6 495×295×600mm20″×12″×24″ 1200m3/h 5
M1-C7 495×495×600mm20″×20″×24″ 2200m3/h 5
M1-C8 595×295×600mm24″×12″×24″ 1600m3/h 6
M1-C9 595×495×600mm24″×20″×24″ 2700m3/h 6
M1-C10 595×595×600mm24″×24″×24″ 3200m3/h 8
*可要据用户要求定制不同规格型号的过滤器
According to user requirements to customize different specifications and types of filters
