苏州德斯森电子有限公司
高速高精度涡流探伤仪
设备概要
DSS-GS18高速高精度智能数字式涡流探伤仪,搭载在win10win7等较新版本平台。采用高性能主机,和处理芯片。操作简单,界面直接,交互友好,较大限度发挥处理器硬件性能和检测优势,维护简单。安全可靠。节能降耗,发热量小。单独的探伤检测软件,兼容性更佳,稳定性更好,容错率更小,故障率更低。操作简单,集成化更高,只针对于探伤检测发挥其较大性能。更适用于铝管、不锈钢管、铜线、铝线、不锈钢丝在线、离线探伤,也可用于机械零部件或者某些异形件的自动探伤。仪器采用较新的数字电子技术、涡流技术以及微机技术,不仅调试、操作简便,性能稳定,且具有可靠、稳定和灵敏的探伤性能。
Dss-gs18 high speed high precision intelligent digital eddy current flaw detector, equipped with win10, win7 and other latest version platform.High - performance mainframe, and processing chips.Simple operation, direct interface, friendly interaction, maximize the processor hardware performance and detection advantages, simple maintenance.Safe and reliable.Energy saving, low calorific value.Independent flaw detection software, better compatibility, better stability, less fault tolerance, lower failure rate.Simple operation, higher integration, only for the detection of the maximum performance.More suitable for aluminum tube, stainless steel tube, copper wire, aluminum wire, stainless steel wire online, offline inspection, also can be used for mechanical parts or some special parts of automatic inspection.The instrument adopts the latest digital electronic technology, eddy current technology and microcomputer technology, which is not only easy to debug and operate, stable in performance, but also reliable, stable and sensitive in flaw detection
DSS-GS18具有单独的测试通道,可驱动不同形式的检测探头,或由较好和差动线圈构成的组合式探头,精度准确,灵敏度高,响应快速。
With independent test channel, can drive different forms of detection probe, or by absolute and differential coil composed of the combination of probe, precision, high sensitivity, rapid response
适用管线材在线探伤
功能参数
频率范围:100Hz-50KHz
增益:0-99db,步距为0.1db
相位:0-360度、步距为1
模式:手动/自动
自动匹配多重驱动
多模式数字滤波:LP/HP/BP/BP-SSF
大中小(ABC)三种启动紧急信号
启动紧急信号区半径可调:0-99,步距为1
幅,线,圈,位多种启动紧急信号设置
启动紧急信号区角度可调:步距为1°。
输入输出拓展接口
电子示波器
电源:220V(-20% ~ +20%)
模拟电子平衡
NG信号输出接口
可拓展多通道
探伤速度:≤1500m/min
生产模式
记录导出实时记录监控
探伤检测统计数据
中英文版(可定制)
l frequency range: 100 hz to 50 KHZ
l gain: 0-99 db, step distance of 0.1 db
l phase: 0-360 degrees, step distance of 1 degree
l modes: manual/automatic
l automatic matching multiple drivers
l multimodal digital filtering: LP/HP/BP/BP - SSF
l medium (ABC) three types of alarm
l adjustable alarm zone radius: 0-99, the interval of 1.
l picture, line, circle, a variety of alarm Settings
l alarm area Angle adjustable: step 1 °.
l input/output interface
l electronic oscillograph
l power: 220 v (20% ~ 20%)
l analog electronic balance
l NG signal output interface
l can expand multi-channel
l detection speed: 2000 m/min or less
l production mode
l record export real-time monitoring
l statistics detection
English and Chinese (customizable)
